Status
Not open for further replies.
1 - 16 of 16 Posts
Fastbrakes 4 Piston Wilwood 12.6" Big Brake kit for '04-14 Acura TSX $550/Shipped
Fastbrakes 4 Piston Wilwood Caliper 12.6" Big Brake kit for 2004-2014 Acura TSX
$550/shipped
I decided to go in a different direction for my front brake upgrade; so I am offering this kit that I spent over $900 on, at a steep discount. It was not used and comes with everything you need to bolt it to your vehicle. Payment is through PayPal and shipping by UPS Ground is included in the price. No PO boxes.
2x Gloss black 4 piston Wilwood brake calipers
2x Centric C-Tek 12.6" rotors for 2004-2008 Nissan Maxima
2x Caliper brackets
2x Stainless steel lines
2x sets of brakes pads [Hawk HPS & Wilwood BP-10]
All required hardware
Instructions
Discussion Starter #4
According to Fastbrakes, this kit will also work on the following vehicles:
1998-2018 Honda Accord (4 & 5 lug)
1999-2011 Acura TL
1999-2005 Acura CL
Discussion Starter #10
Would this fit Enkei Nt03 18x9.5 +40 rims?
I don't think so. I have stock 17x7 wheels with 55 offset and I am running a 25mm spacer to clear my RL brake upgrade. You will most likely need to run some sort of spacer with these.
Discussion Starter #14
I tried a 15MM spacer and it allowed my wheels to clear the calipers. There was some room left, so a 10mm spacer may work as well.
Discussion Starter #16
I have recently upgraded to Gunmetal 18x8.5 A Spec Wheels. They have a 45mm offset and clear the RL calipers with a little room to spare. If you have similarly spec'd wheels you most like will be able to do this upgrade without a spacer. The stock 17x7 [55mm offset] wheels, I recommend at least a 10-15mm spacer.
1 - 16 of 16 Posts
Status
About this Discussion
5 Participants
ebayking90
Acura TSX Forum
Full Forum Listing
