Status
Not open for further replies.
1 - 7 of 7 Posts
iVTEC no koe
Sold!sold!sold!
SOLD!SOLD!SOLD!SOLD!
Reason for selling: Bought this originally along with an ACT TSX clutch, installed right before I stored my car for winter, put less than 500kms on it. After winter, I attempted to drive the car, it wouldn't shift into gear. Towed to garage, it appears the pressure plate was defective and the plate spring broke. I needed the car to drive and the only thing in stock was RSX-S stuff, so I switched to that.
Asking for $180 (Price drop from $220), I paid $360 for it.
I can meet up anywhere within 5-10mins from the red line or within the blue box of the map. To clarify again, this will ONLY mount up to the stock OEM clutch, or any other TSX-specific clutches.
Reference info:
Fidanza Product Display
Marketing fluff
Acura TSX Fidanza Aluminum Flywheel - 191241
Fits: 2004-2007 Acura TSX 2.4L
Uses Plate Part# 229101
Aluminum Flywheels
Our aluminum flywheels are made from the highest quality 6061 T6 aluminum. The material is fantastic for strength, heat dissipation and of course reduction in weight. The friction surface we use is an incredibly strong 1045 steel. The plates are milled to meet our high specifications.
A Fidanza flywheel can mate with any type of clutch material, including organic, kevlar, ceramic, metallic and sintered iron. We attach the replaceable friction surface with military grade aerospace fasteners. With these replaceable plates there is no need to replace the entire flywheel when the clutch or flywheel is at the end of it's life, saving time and money. The ring gears we use are also made from 1050 steel and are heat treated for durability. The gears are heated then pressed on and secured with grade 8 button screws.
Fidanza was the first to utilize a stepped dowel system in most of our flywheel applications. This doweling method ensures that once the pressure plate is installed the dowels cannot be removed because they become locked into place. No chromemoly can compete with the awesome serviceability, strength and superior design of Fidanza's aluminum flywheels. If there was a better material out there, we would be using it.
Hardware
STEPPED DOWELS: ONCE PRESSURE PLATE IS INSTALLED THEY BECOME LOCKED IN PLACE
FASTENERS: MILITARY SPEC QUALITY
REPLACEABLE FRICTION PLATE: 1045 STEEL
RING GEAR: 1050 STEEL / HEAT TREATED FOR DURABILITY
BODY: 6061 T6 ALUMINUM
1 - 7 of 7 Posts
Status
