This is a fix for the oscillating sound you might hear when braking only. It is a short interval scraping sound that matches the speed of your rotor, slowing down as you do.
This occurs because the brake pads have become stuck or pinched between the shims of the caliper. They are designed to move slightly as they glide along the surface of the rotor. Once rust, debris, or caliper paint build up, they begin to stick. What you hear is the "nubs" of the brake pads scraping against the shims.
Read; do not attempt if changing brake pads is beyond your skill.
Difficulty: 4/10 (Some rotary grinding)
Tools needed:
Step 0:
Put your PPE on.
Step 1:
Jack up car relative to which brake & rotor is complaining. Make sure you do this the right way.
Step 2:
Remove the brake pads. Use the abundant guides available on the interblog or search the Google.
Two 12mm bolts on the caliper. One 12mm bolt on the brake line to free up some slack. Do not let it dangle.
Step 3:
Remove the caliper bracket that secures the caliper to the wheel hub. This will require the 14mm socket.
Test the two small caliper pistons (littlerubber accordion looking parts) to ensure they are not seized. They should compress and expand smoothly, returning to their natural position on their own.
Step 4:
Remove the shims from the caliper bracket. Use the flat head to push them off at the middle part pressure clipped in the bracket's depression.
Step 5:
Using quick clamps to hold the shims (fingers away), polish the shims clean with the wire brush bit.
Dremel:
Wire brush bit:
Dirty shims
Cleaner shims
Step 6:
Secure the bracket with the clamps. Using a metal grinding bit, clean off the contact areas. Keep the bit moving to prevent gouging the surface. It should remain flat. Light pressure works fine.
Bit:
Dirty bracket:
Cleaner bracket:
Step 7:
Use the grinder to clean the nubs of the brake pads.
Dirty brake pad:
Cleaned pad:
Step 8:
Apply anti seize to all the polished parts. Avoid getting it on the rotor surface and pad surface. Also apply to bolts removed.
Step 9:
Put it all back together. Make sure shims seat properly and securely. Unbend the little tabs to make a tighter fit in the bracket depression. Shims should sit flat against the bracket. Adjust as necessary.
Ensure brake pads slide on easily. This is the whole point!
Step 9:
Get your car back down without it toppling over in you.
Step 10:
Test your brakes. Bed them in if necessary (More Googlies if you don't know how).
Step 11:
+Rep & thanks
Sent from AutoGuide.com App
Tools needed:
- Jack
Jack stands
Lug nut wrench
Socket (extension, 14mm, 12mm)
Anti-seize
Flat head screw driver
Rotary Tool (metal grinding bit, wire brush bit)
Mini Quick clamps
- Glasses (Mandatory, you're stupid if you don't, plain & simple)
Gloves
Long sleeves
Step 0:
Put your PPE on.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Dremel:
Wire brush bit:
Dirty shims
Cleaner shims
Step 6:
Bit:
Dirty bracket:
Cleaner bracket:
Step 7:
Dirty brake pad:
Cleaned pad:
Step 8:
Step 9:
Step 9:
Step 10:
Step 11:
+Rep & thanks
