1 - 2 of 2 Posts
Hi,
I've bought a kit from K2Motor and installed it with the push button.
Today I've changed it and installed a combination switch with front fog light option.
Followed the installation instructions given by Peregrine carefull but now they don't work.
The light on dash panel lights up but the 12v signal (to relay coil) given by 14pin connector isn't there.
Have anyone have the same issue or there's any fuse that I have to check?
Thanks
Discussion Starter · #2 ·
"Problem" solved.
The pin #3 on 14 pin connector doesn't carry a 12v signal. When you turn on your fog lights this pin is connected to ground instead carrying 12v to activate the relay coil.
Thanks
1 - 2 of 2 Posts
