i have oem fog lights and recently my fogs lights stays on all the time even when the car is off, i have to disconect the battery so my battery doesnt drain, or remove the fuse.
did anyone have the same issue or knows a way to fix this ?
Do you have a 06-08 with stock foglamps?
I don't have this issue, but I'm wondering if your fog relays are "stuck". How good are you with electrical and multimeters? I would troubleshoot the relay either with multimeter or swapping it out.
2005 tsx , how do i test it with a multimeter
You can try this:
https://axleaddict.com/auto-repair/how-to-test-relays
I don't have the pin diagram for that relay, but generally speaking a relay works in this manner: It will have a couple of pins that sense when a switch has been engaged (such as turning on a switch on the dash), and that energizes (flips the internal switch), to allow a higher current flow through the other two pins of the relay to your fog switch.
It sounds complicated, but it really isn't.
About this Discussion
3 Participants
Kriscl9
Acura TSX Forum
Full Forum Listing
