1 - 20 of 36 Posts
This question is for those that had the fog lights installed by the Acura dealer (as a dealer installed option). Are they always on when you turn on your headlights or do they have a separate switch where you can choose to turn then on or off when the headlights are on?
Thanks.
TSX Fog Lamps have a separate switch that is not mounted on dash as was typical of Honda products in the US.
The switch is located on the turn signal stalk and requires the steering wheel to be pulled and the OEM stalk to be replaced with a new one that comes with the kit.
Not as difficult as it sounds, but it is time consuming.
I had my fogs installed by the dealer... You can turn them on or off at your leasure...but you can only turn them on when your headlights are on. You can't turn them on when your parking lights are on. Speaking of fog lights, is there anyway of wiring it so the fogs can come on when the parking lights are on?
Carlos8542222 said:
Hip: When you say "pulled" you mean they have to pull OFF the steering wheel from the car?
Thanks for the responses guys.
You got it, not very hard.
Here is the instructions from my old Ody, very similar procedure.
they also turn off when the high beams are turned on
The Voice of Reason
The steering wheel is not usually pulled, but the steering column cover is removed. The installation instructions are available online from the Acura parts discounters like this one: http://www.hondacuraworld.com/Merchant2/merchant.mvc
The fog lights are $279.50 from the above merchant, and I installed them myself, so that would be $279.50 total.:)
I had the same issue with my wife's Odyssey. I purchased the Honda OEM fogs and installed them myself, but I was unhappy with the fact that they only operated with the low beams. If you just had the parking lights on, or the high beams, then the fogs would turn off. Someone at www.odyclub.com got the helms wiring diagram and figured out how to rewire the fogs to work with parking lights, low beams and high beams. It was only a matter of dicsonnecting one relay, and running a jumper between two wires. I am not that mechinically inclined, and I was able to do the install and the mod in about 4 hours.
When I (hopefully!) get a TSX, I hope to find someone that can provide the same modification information.
1 - 20 of 36 Posts
