look at the picture of the front shock, don't you think there is a problem with the Koni's design? * the shock tube body is like a straight rod with same diamenter. don't you think the shock will potentialy slip down and hit the axle??
with the other manufacturers, their designs are like very secure because the diameter on the bottom part is larger than the upper, therefore not going to slip down and hit the axle
