Up for sale is my beloved 2007 Acura TSX 6MT. Car has been meticulously maintained with and very clean car inside and out. It’s an open canvas ready for tuning and any other mods you want to throw at it. I’m only selling it to make room for the GR86 that I have on order. Asking price is $9K OBO. Not interested in any trades.
Car Details & Mods - Vehicle is mostly stock with some OEM+ type mods
  • 2007 Acura TSX (Hondata FlashPro ready)
  • 6 speed Manual Transmission
  • 132K miles
  • 2nd Owner since 62k miles
  • Clean Title (Autocheck vehicle history report provided)
  • VIN: JH4CL95807C005262
  • OEM RSX Type S VTC actuator pinned to 45 degrees by HyTech Exhaust
  • Hondata intake manifold gasket
  • P2R Throttle Body Gasket
  • UR underdrive pulleys (Crank and Alternator Pulleys)
  • Stoptech Stainless Steel Brake Lines
  • Hybrid Racing Shifter Bushings
  • OEM Aspec underbody lip spoiler kit (Complete kit for Front, Sides, and Rear)
  • Fastline Rear Lip spoiler color matched
  • Factory Aspec suspension
  • OEM Acura TL Type S rear sway bar
  • OEM Acura TL Type S rear end links
  • Spoon Rigid Collar for Front and Rear Sub Frames
  • Phantom Audio Retuned radio amplifier (this is a replacement of the factory amplifier)
  • JBL GT7-6C speakers for the front doors
  • JBL GT7-6 speakers for the rear doors
  • Alpine Type R speakers for the rear deck
  • Sound deadening in the doors and rear deck
  • Full LED interior lighting
  • Front Dash Cam
  • OEM Civic Type R Shift Knob
Maintenance Items - I have a spreadsheet that tracks all of the maintenance items. Here are the major highlights:
  • Oil change every 5k miles
  • Techron Fuel System Cleaner every 5k miles
  • OEM VTC Strainer Gasket replaced @130k miles
  • OEM VTC Solenoid Spool Valve Gasket replaced @130k miles
  • OEM PCV Valve replaced @130k miles
  • OEM Transmission Mounts (all of them) replaced @ 129k miles
  • Michelin Pilot Sport AS4 Tires installed @ 123k miles
  • OEM Upstream O2 sensor replaced @ 123k miles
  • OEM Motor Mounts (all of them) replaced @ 123k
  • OEM Subframe Middle Mounts (Left & Right) replaced @ 123k
  • NGK IZFR6K-11 Spark Plugs replaced @ 120k miles
  • Professional Fuel Injector Cleaning Service done @ 120k miles (done at RC Fuel Injection Inc in Torrance, CA)
  • OEM Power Steering Fluid replaced @ 120k miles
  • EGR Plate Clean with Gasket Replaced @ 119k miles
  • Nippon Denso Alternator Replaced @ 118k miles
  • OEM Front LCA Compliance Bushing replaced with Acura TL Bushing (51394-SEP-A01) @ 117k miles
  • Exedy Clutch and Throwout Bearing Replaced @ 109k miles
  • OEM Front Sway Bar Bushing Replaced @ 109k miles
  • AC Compressor, Condensor, and Recharge done @ 108k miles
  • Interstate 12V battery replaced @ 108k miles
  • OEM Power Transistor (79330-SDR-A01) replaced @ 105k miles
  • Redline Manual Transmission Fluid replaced @ 101k miles
  • Brake Pads (Front & Rear) + rotor resurface @ 95k miles
  • OEM Honda Brake Fluid Replaced @ 95k miles
  • OEM TL Type S Rear Endlink Replaced @ 95k miles
  • E-Brake Adjusted @ 91k miles
  • OEM Clutch Master and Clutch Slave Cylinder Replaced @ 85k miles
  • Gates Drive Belt Replaced @ 85k miles
  • OEM Coolant Replaced @ 83k miles
  • OEM TSX Front Endlink Replaced @ 83k miles
  • Valve Clearance Adjustment @ 82k miles
  • OEM Valve Cover Gasket and Spark Plug Gaskets Replaced @ 82k miles
