I'm having the same problem. I am going to try hitting the button on the garage door mechanism to see if that will work when I get time. You should have that as well.
That worked for me when my parents garage door wasn't syncing. It was very frustrating until I figured that out. My sisters didn't need it though so it all depends.I'm having the same problem. I am going to try hitting the button on the garage door mechanism to see if that will work when I get time. You should have that as well.
If you're experiencing difficulties programming your high-end Genie belt drive garage door opener with your newer vehicles, here are a few suggestions to troubleshoot the issue:I have a high end genie belt drive garage door opener that has rolling codes. to program you have to go through the normal point-the-remote-at-the-visor setup routine and then push the "LEARN" button on the motor drive unit and go to the car and push the button there again. Can't get it to work.
It worked great on my 1999 mercury and my 2004 infinity whcih should have been older and lower tech cars. but they were made about the same time as the garage door opener which I bought in 1999.
Any suggestions?
thanks,
Jerry
