1 - 19 of 19 Posts
This problem is on a 2012 TSX 4 cyl, 5sp auto, 147K miles.
The shift from 1st to 2nd is delayed. The car gets out of 1st, the rpm's increase, if I'm not careful, until the trans finally engages 2nd. Then it engages with a car shuddering hard shift engagement. It seems to happen most often after the car warms up.
I only have the hard shift between 1 and 2.The rest of the up shifting is normal. No problems with down shifts.
There will also occasionally be a shuddering like the trans is trying to figure out if it should be in gear or change to another, can't decide, so it vacillates between in gear or starting to shift then going back into gear. If I let off the throttle or give it more gas, it will settle down.
I've checked the trans fluid level and it is good. I do not know how old the fluid is and I've made an appointment with my local mechanic to do a flush tomorrow.
No check engine light. No other electronic indicators of problems.
  • Like
Reactions: Leke
Discussion Starter · #2 ·
The tranny flush has been done with no change in how it shifts.
Discussion Starter · #4 ·
I’m having this exact problem. Did you ever figure out the problem? Or a solution?
No I have not. It does shift better but I still get the delayed 1-2 shift once in a while.
Discussion Starter · #6 ·
I only did the flush. You could tell that the fluid that came out had not been flushed in a very long time. It was an ugly brown color.
There are two pressure sensors I will replace in the near future to see if that will also help.
I’ve just ordered these two pressure switches and will be replacing them sometime next week when I get them. I will report back after I get them replaced.
28600-r90-004
28600-r94-004
Also plan on pulling the linear selenoid to clean the filter but I have to order the gasket so that will be if replacement of the switches don’t fix the problem.
I replaced both 2nd and 3rd pressure switch as well the transmission filter and still no change. I also took out the shift selenoid and tested them to be good so put them back. Both are around $800 so didn’t replace them. At a dead end so I guess drive until it falls apart.
What did you do or what part did you replace to make it drive better? Can you share it with me? Thanks
I have a 2012 TSX as well and had the same issue for months. I had to get my transmission rebuilt. The cause of the issue was this O-ring breaking (see attachment). The mechanic said even if we would have caught it early they still would have to do a full disassemble and reassemble.
Can you tell me the name of this part that need new oring? Or have the oring part number? I’m wondering how difficult it is to replace it?
roirraWFStnaiG
Has anyone been able to find a solution to this? I'm having the same exact issue. I've taken mines to a local shop and the mechanic told me that it could be a Shift Solenoid problem. He took mines off and cleaned it with brake cleaner and a pistol grip air compressor. But I can't seem to find out how many shift solenoids we have in our TSX in case I wanted to do the work myself.
Has anyone tried to cleanup the transmission solenoid filters inside
1 - 19 of 19 Posts
