idk about a write up but its not hard, just time consuming
Remove the back seat bottom-
Remove back seat side bolsters-
remove A, B, C Pillars-
Then remove everything that is screwed to the roof-
The trick is getting the headliner out of the car without bending it all up. If you bend it there is no way to get the creases out of it, so take your time and DONT BEND IT!
Also note, DO NOT use a drill to screw anything back together...you could over tighten screws and dent the roof outward.
What are you planning on doing with the headliner?
