hello guy i have a 2004 tsx that it was fine until i got the vsa light on and a small triangle light on. any ideas?
Shaka!
it might just be an electornic disturbance. maybe one of the sensors is not working properly. check the fuse/relay box under the steering wheel on the left side and also check the fuse nder the hood. depending on how you drive your tsx, its most likely an electronic thing. if you still have the warranty then you should be fine if its something serious.
Or you could try and push the "VSA" button (left lower dashboard, rectangular button).
Simplest fix first, I always say. ;)
Shaka!
no, that wouldn't fix the VSA indicator, maybe for the triangle. I had this problem once and it was because there wasn't enough air pressure in the intake manifold due to the rubber elbow on my injen CAI getting loose.
