I am having some clunking on the passenger side of my car (2007). I believe it is the lower control arm bushings so I ordered new lower control arms online. I will be doing the install this week but have a few questions for all you pro mechanics.
I am not replacing my ball joint just my LCA.
1. So I have a new lca. Does the ball joint come off with the lca when I remove it or does it stay on the car?
2. Do I have to use a ball joint separator tool to remove the lca from the ball joint?
3. How would I press in the ball joint to the lca if needed?
I have done lots of searching on this but really have not found an easy answer. Please provide steps if you can. Thanks for all the help in advance
