1 - 12 of 12 Posts
My multi disc changer is out & I just wanna confirm if a 2005 radio will work on my 04. Do any of you guys know???
long-term build
2004 part number: 39175-SEC-A02
#7 in above picture
2005 part number: 39175-SEC-L01
#7 in above picture
so the 2005 is a different part number.
and it's listed with (PANASONIC) written in the description.
so it appears to be a different player all together.
these suckers are over a grand new, so good luck man.
I can't tell if it'll work or not, i can just tell they're not the same.
Discussion Starter #4
#7 in above picture
#7 in above picture
Tnx MMs for the info. pix dont work btw...
Im getting a used 05 from a member here & Ill let you'll know if its going to work once I receive & install it.
long-term build
howdy.
pics work fine on my monitor.
I don't always host pictures myself on my own photobucket, too much
work for me sometimes. so I often just copy the URL link and make it work.
often times these dealer pictures don't show up, but if you refresh the page,
or go to internet options and clear your cache, it'll then work.
not too sure why.
Discussion Starter #6
howdy.
not too sure why.
lol... now I see it. tnx
wine em, dine em, cl9 em
ugh can't find it. it will pop up again. i will be sure to quote it instead next time!
edit: i think i remember him being in the 408
Discussion Starter #11
#7 in above picture
#7 in above picture
UPDATE:
2004 radio will work on 2005. They are just diff part # that's all.
I got a use radio from k20z100. CD changer & the print circuit board (PCB) wasn't working.
(Note: The CD changer is connected with PCB. You'll also need a new code.)
Then two days ago I receive the replacement that was not working. Thx k20z100 for the plug & giving me the instruction how to remove the radio. I will take some pix how I remove the radio by Sun.... I hope. :laugh:
Discussion Starter #12
How to remove the OEM radio
For got about this. Here you go...
#1- Take out silver trims of the dash there are 2 screws on each side... You'll need a flat head and rag/cloth.
#2 Pope out hazard signal button there is one Philips screws....
Pass. side
Driver side.
#3-Take out under radio pocket there are two Philips screws
#4 Take flat screw driver ones all the screws are removed and just pop it out then when it comes out unplug the hardness and u ready to install another radio
1 - 12 of 12 Posts
