1 - 15 of 15 Posts
I've been looking everywhere and can't really find much on the set up I'm looking into getting (for a 04 TSX) which is
18x9.5 +35 wheels
235/35/18 tires
with a 1.9 in drop in the front and a 1.4in drop in the rear
(lowering springs no coilovers)
or would I be better off getting
18x8.5 +35 wheels
225/40/18 tires
same springs
Not looking for the crazy "HellaFlush stretched tire" look just a clean fitment with no issues for a daily driver.
My question is would I rub or have any problems with either set up or need to roll and pull the fenders (mainly the 18x9.5 +35 235/35/18 set up) on the little drop that I will have.
If someone can please spare some knowledge I would very much appreciate it. :)
Would it be too much poke cause I know stock offset is +55 what if I go with those skunk2 coilover sleave kit I know there's as much as a 3in drop on those (I'm on a part time job budget lol) thanks for the fast comment
True Honda Head
Is this only for looking purpose because, the less you drop, the wider you can go. My 2 cents...
You will rub without the natural camber unless you are running extreme springs rates. That is why he is telling you that it's not enough drop.
Discussion Starter · #6 ·
Yep it is, and a daily driver. I just don't want to rub or anything. Its no problem I can get the fenders rolled, but I just want to know the widest wheel I can go with the least amount of modding (fender pulling, camber kits, spacers)
Discussion Starter · #7 ·
Ahh I see. I just haven't seen tsx's with a set up similar to what im trying to go with. Or any with the cheap ($270) Skunk2 coilover sleeves so I'm trying to do as much research as I can before I make a $900 purchase on wheels.
True Honda Head
An 8 or 8.5 would be ideal with a high offset. Natural camber is your friend but you want to go lower so you can take advantage of it.
I </3 NY ROADS
Discussion Starter · #12 ·
1 - 15 of 15 Posts
