1 - 3 of 3 Posts
2004 TSX 6-spd Stock
Just installed. 06 tsx manifold/throttle body on my 2004 tsx and got a code p1683.
I disconnected the battery and tried doing the idle reset and car was fine and on the 5th start up code pop up again and car super slow..
Throttle Valve Default Position...take a voltmeter to see if there is continuity between tabs on the sensor or if you can get a cheap one at the junk yard and see if it changes anything.
1 - 3 of 3 Posts
