1 - 2 of 2 Posts
I changed my starter on my 2008 tsx and now it makes a funny noise when i start it. it sounds like its not catching the flywheel but it does start. so pls can u guys help me out thank you.
Did you replace your starter with an OEM Honda starter or an aftermarket remanufactured one? My starter just went out and I replaced it with a aftermarket remanufactured one and it does sound different. As long as it's not making a grinding noise (which comes from the starter gears grinding on the flywheel teeth) then it should be fine.
1 - 2 of 2 Posts
