Hi.
I am a 2004 EuroAccord 5 A/T user.
I'am planning to install gear change buttons to the wheel.
Prior to plan what kind of buttons to use, I wanted to learn abour the sistem.
When switching to "M Mode", what do we trigger by shifting + or -?
Is it mechanical or triggered by a switch?
If it is triggered by switches, it can be done.
Waiting from experienced guys.
Regards,
Türk
All you have to do is look at the top of the transmission, get somebody else to start the car, put it in drive and in manual mode, then change gears. If the cables move when changing gears, then its not electronic. If nothing moves, then its controlled by switches.
you are commanding the transmission ECU to upshift or downshift. It can be done if you can fabricate the buttons.
