I didn't know how to title this but I recently did a hondata gasket install I did drain a little coolant but not alot since I just did the flush not to long ago, wish I had the gasket then. Anyways to the question when I was removing the injector base to take out the gasket, lets say about three eye drops worth of a size of coolant went into the engine close to where the coolant is located. Should I get worry about it after install everything looks good I refilled the coolant check for any leaks and also smoke and no engine codes.
Any advice would be great thanks
