1 - 8 of 8 Posts
Negative
Does a ECU with the reflash for the TSX 06 works on TSX 05?
Thank you.
do you have an euro accord as stated under your avatar on the left?? <<<
youl need an tsx 08 ecu and flashpro
^^^Are you guys sure?
I could have sworn I've read that a few guys have done exactly that. 2006 TSX ECU swapped into a 2004-05 TSX.
Theorizing:
Since a 2007-08 ECU can be swapped into a 2004-06 TSX using the same the Hondata OBDII jumper harness, then the 2004-06 must have the identical pinouts & then must be swappable also.
Just thinking out loud here...
Of course you would need a Honda dealer to sync up the RFID/chip keys & you must keep the transmission type (auto or manual) in mind.
No idea for the TSX's to be honest i have a euro accord.
if hes after a remap / reflash he needs the tsx 07-08 ecu and flash pro with the little jumper harness thingy.
that is of course if he has a euro
did that make sense? :laugh:
If you want to test your theory I am considering selling my 06 5AT OEM ECU with immobilizer, key cylinder and switchblade key, all synced. If you don't want to replace the whole key cylinder you can reroute the immobilizer with the valet key instead under the dash I believe, it was a pretty big job changing the steering lock and all that.
Discussion Starter #8
Yes, I have a 05 Euro CL9 MT.
A friend of mine has a 06 Euro CL9 MT with a Hondata reflash ECU (he bought this ECU in UK).
We want to know if this ECU will work in my car.
1 - 8 of 8 Posts
