So here's my dilemma. I HATE my car right now. The car itself is great, but the vibrations at idle are horrendous. I originally had what I thought to be worn engine mounts, so I replaced 3 tranny mounts (6MT) and the front and rear engine mounts. All replacement mounts were "Anchor" brand. Tranny mounts seem fine with exact feel as the OEM ones. The engine mounts seemed fine (heck they even had the OEM part number stamped into the rubber).
However, the front mount did NOT have a tube for the hydraulic / dual-density feature that the OEM mount has. As a result, I capped the tube off with silicone and a screw (couldn't find a cap to fit), and the current non-OEM mount is obviouusly not using the hydraulic feature of this car.
The idle vibrations are intense and terrible and I can see my hood vibrating, my change tray rattles, and water in a water bottle will dance and have a small typhoon in it while at a stoplight.
Does anyone here think going back to a new OEM mount with hydraulic connection will solve this problem?
For reference, I had a 1991 Integra with Energy Suspension polyurethane inserts, and even in the middle of an Ontario winter, it was vibrating less than the TSX currently is.
