1 - 2 of 2 Posts
Master of the turbo
Hey I Would like to keep my stock primary O2 sensor and as I understand the secondary sensor is narrowband anyways, so I would like to replace that with a wideband and have an additional pinout in the ecu that could read those readings for tuning reasons. But I am completely lost as to how to do this, tuning with flashpro btw
Pulled right from the Hondata Flashpro help file for the TSX. This only works if you have the 07-08 ECU conversion (or an 07-08 TSX) and Hondata Flashpro.
TSX 2007-2008 ECU
PIN B16
Boost Control output (EGR)
Normally unused.
PIN B12
Wideband input (EGRL)
Wideband input
Normally unused.
PIN B22
Wideband input
Wideband input
Normally unused.
PIN E15
ELD - Electrical load input
Wideband input
ELD must be disabled & factory pin must be removed from the ECU connector.
1 - 2 of 2 Posts
