1 - 16 of 16 Posts
Alliance!
So my question is, wouls an offset of +28 have me flush over a bit over-flush with the fenders?
Alliance!
Discussion Starter #4
Sorry guys lol, 9.5
fresh to death
you would still need to do fender work as well as going negative with camber...are you planning on running this all around...?
i know it can be done, because there are a few people that are 9.5 wide with a lower offset...
Alliance!
Discussion Starter #6
The next lowest offset would be +12. I do plan on going all around. I'm not going to be dropped too low, just 1.5 or 2 inches a best. I dont want hellaflush, just flush with the fenders.
Alliance!
Discussion Starter #8
It probably will but I'm tracking the car soon. Want to go wide with out being too ridiculously far from the fenders. Didnt Marcus go with 17x9.5? Or was that a 17x9? I think his looks fairly decent.
" It Is What It Is "
18x8 +40 is flush with fender...borderline if you ask me...
I </3 NY ROADS
That setup will stick out past the fender, not ideal for tracking unless you want to pinch your fenders. If you really want 9.5 i think Marcus is +40/45
Alliance!
Discussion Starter #11
Ah, so the lower the number, the closer to the car?
I </3 NY ROADS
Lower the number the more it sticks out. The higher the number the closer it sits to the car. 9.5+28 will sit past the fender unless you run negative camber.
Alliance!
Discussion Starter #13
Oh I get it now, thanks, I found a set at +35. Thanks guys!
fresh to death
i agree with what others said..i really wouldnt track with those specs...i could go with a higher offset...
1 - 16 of 16 Posts
