My ring gear sheared some teeth, so I had a new trans built to my specs. While I had my trans out I decided to replace the clutch and flywheel.
Picked up an Exedy OEM replacement clutch kit for an Si/RSX-S, and a Competition Clutch 11.5Lb flywheel. Its 4140 forged steel, and the quality is top notch.
I cant' really give you a fair opinion on any gear but first and 6th, as my 2-5 are Si gears and would accelerate much quicker regardless of flywheel.
As for 1st gear - if not throttled back, its wheel spin through about 1/2 the RPM range until it catches. Even with feathering it's very easy to accidentally lose traction in the lower RPMs, even if you've already got the car moving.
6th is VERY slightly quicker to accelerate without downshifting, though without using a stopwatch you most likely wouldn't notice. It does however still give you the idea of how freeing up rotational mass helps with transferring power beyond the crankshaft more efficiently. This will also help with fuel economy.
If neutral-ed out, the engine will free-rev INSANELY fast in comparison to the stock flywheel. Between shifts the RPM drop is very fast, but not too quick to cause issues with casual shifting. The free-rev increase definitely helps out when downshifting at higher speeds. Taking off from a stop is not noticeably different to me, even with having less stored energy in the flywheel than before.
Again all I can fairly judge is 1st and 6th. Between installing the short 2-5, and the Si LSD, any other gear would be affected much less by the flywheel when compared to the stock TSX gearing.
If you're having to pull your trans for any reason, or due for a clutch job, I'd highly recommend it. The part number is 2-800-ST. It's usually listed under 02-06 RSX-S and 06-11 Si. This flywheel MUST be paired with a clutch for either the above vehicles (The part numbers will be the same for either vehicle as well).
As for the Exedy OEM replacement clutch kit (also for the RSX-S/Si), the pedal is actually noticeably softer. I like it. It's also caused my master cylinder to stop the ever-common "popping" they're known for. This is of course due to the lower hydraulic pressure being exerted, but its a welcome plus.
Also, no chatter has been experienced with this combo.
Variables during the evaluation:
- 134,131 mi.
-No engine mods. No reflash. Stock exhaust. Stock intake with resonator removed.
-Wheels: OEM Honda Civic Si optional 18" HFP's.
-Tires: 215/45/18 Continental ExtemeContact DWS with aprox 6,000 miles of use.
-Dry, well-paved asphalt roads. 60-75% humidty. 82*F
On a side note: If you can get your hands on 02-06 RSX-S or 06-11 Si gears for a fair price, it's an amazing upgrade. Add an LSD (Aftermarket or OEM) from any K series trans, and the combo becomes perfect for the TSX. Acceleration with the shorter 2-5 while still retaining the stock 4.7 final drive is greater than leaving stock TSX 1-6 and using a 5.06 final drive (though that is an AMAZING trans for a swapped K24 chassis!!!)
Cheers!:festive:
- 134,131 mi.
Cheers!:festive:
