1 - 3 of 3 Posts
Hey,
I have a TSX i-VES DVD entertainment system that i got from a friend. I just have the DVD player itself and not the 7 inch LCD screen that comes with the kit. I was planning to install two 5 inch LCD screens in the headrest of my 2004 TSX and plug it into the factory dvd player that i have. The problem that Im having is that the Accura Factory DVD player doesnt have a RCA jack in the back that i can plug the tv's to.
Here is the website for the installation instructions for the i-VES DVD entertainment system, http://www.handa-accessories.com/tsx.html
Any suggestions or help on my project would be appreciated. Has anyone done this before?
Yeah, you might not be able to use that with an aftermarket monitor. If it uses a standard composite video out with a single signal and single outer shield wire in the harness, you can cut those two wires and solder a RCA end onto it. A lot of the newer factory video systems use seperate RGB signal wires and these formats are NOT compatible with aftermarket monitors. You will need to find a wiring diagram and/or pinout of the DVD player's main wire harness to find out for sure.
1 - 3 of 3 Posts
