1 - 6 of 6 Posts
Finally got these installed a couple days ago.
its weird, constant cornering no noise. i can push the spring down no noise. its just slower speed when the weight shifts if i give it throttle that it makes an odd crack noise. almost like crushing a can. It sounds like the front passenger side.
Odd thing is i went an got an alignment and the passenger side front came out at + .6 degrees, while the driver side was -1.3 I expected negative camber due to lowering it a bit, but not positive. So that is weird.
Here is a vid. Around 6 or 7 seconds is probably the best
Everything seems pretty darn tight. Any ideas ?
Loose sway bar?
1 - 6 of 6 Posts
