1 - 3 of 3 Posts
Hey guys i have a question, i just bought a jdm k24a (RBB head high comp) and i am going to install a 2006 acura rsx type s oil pump and rbc cam gear, my question is can i just slap on the rbc cam gear, how do i adjust it (on or out of the motor) and what should i adjust it too? Thanks in advance
Will have to get it pinned at 25 degrees as the stocks can only handle up to 25 if you want to be at 45 or 50 degrees would require that you run 07/08 ecu with hondata flashpro
1 - 3 of 3 Posts
