Yeah since the RRC adds HP and tq and isn't very expensive and bolts right in, why bother w a possible bad port job that wastes time and
If it was just that easy!!
Have a close look at the dyno curves for the short runner intake manifolds. They add high rpm power at the expense of low end torque.
If you have a near stock TSX (which is a heavy car) or if you have an automatic trans, the short runner intake manifold will make the car slower & feel like a dog.
Here is an example:
Tuning the TSX
The guys having success with short runner intakes are the guys with aftermarket cams, possibly higher compression & revving their engines higher. Plus custom FlashPro ECU tuning.
Extrude honing long runner intakes in other platforms has been successful. My older 5.0L Mustang has an extrude hone Cobra long runner intake manifold. This added top end horsepower nearly equal to a short runner IM but with no low end losses.
Any time you are looking at engine upgrades, you must take the entire rev range of the engine into consideration. The area under the HP & torque curves.
Higher peak HP & torque gains but less area under the power curves can actually make for a slower car. It happens all the time & can be witness at "street drags" at your local drag strip.
