1 - 2 of 2 Posts
Hey guys so I was going to take a picture but it's pretty self explanatory.
So I took my regular bulbs out of the door to replace them with LED ones. As I was doing this the actual holder that you insert the bulb into got pushed in through the hole its regularly placed in and is IN the door.
I can't retrieve it with my fingers or anything
Is there and easy way to get it out? Or do I have to take apart the door siding? Thanks in advance.
四世
You could try using a set of narrow tweezers maybe? If not, taking off the door cover isn't that hard. Purchase a set of these and it should only take a few minutes.
1 - 2 of 2 Posts
