Hello all, I recently purchased an 06 TSX and am just starting to have some issues with the interior lights flickering, and the Air Bag light coming on for about a second. At first the stereo will just pause for an instant, then as time goes on, the lights flick along with the pause in the stereo. I also noticed that when I switch the headlights from the low to the highbeams, this causes this flicker as well. After noticing this, I was testing what else might make them flicker, and when just flashing the highbeams once, it shut off all the lights completelyfor a second and the airbag light came on, and then went off again... After this happened, I noticed my driver side low beams wasn't working. I then manually turned off my lights and back on after a second and both came on again.
I read similar issues on here, but not exactly the same. I was told when I just bought the car that a brand new battery was just installed. Possible that this is what is causing the issue? Any recommendations?
