1 - 7 of 7 Posts
my cars radio stopped making sound but still works like lights up and numbers and all my blue led which light up shifter won’t turn on and my tail lights do light up also my ac doesn’t blow cold but Idk if that’s all related can anyone help
Sounds like a fuse has blown. Not sure which one off the top of my head but it should be in the fusebox under the drivers side dash.
Discussion Starter · #4 ·
Ok so up date I fixed the radio ,now it’s just the lights and the ac not blowing cold , also my door dosent open with the remote nor from the inside
I’m going to guess that none of your remaining issues are related.
AC is most likely either needing a recharge or the compressor isn’t engaging properly.
Still not exactly sure what you mean about “shifter won’t turn on”. Are you referring to the gear indicator in the gauge cluster?
Door could be a variety of things, the interior door panel will need to be removed regardless though. I’m assuming it doesn’t open under any circumstances? Even when it’s unlocked?
1 - 7 of 7 Posts
