JDM > Mugen
This sound like a dumb post but almost every car i see that have ABS have an ABS warning light when ABS is activated...
I don't see on mine.. is there one for TSX... or is it a myth
>.>a
thx
Yes, there is. If you haven't seen it, it's because you haven't activated it yet.
Or you were looking over there <<< or over there >>> and not right there. :D
, Administrator Emeritus
I look at the instrument cluster everytime I start the car and I'm very sure to say ... There is an ABS light. However, the ABS light will not activate unless there is a problem with the ABS system, module, controls.
The Honda ABS warning lamp is only used as above. It is not used as an active indication system. The only "active" light on the instrument cluster on the CL9 is the VSA warning lamp, all else should not be active or constantly blinking or lighting up without an induced driver action.
