1 - 20 of 27 Posts
I am looking to do a JDM K24a swap as my K24A2 is showing its age, burning a lot of oil. The motor is still healthy still pulls but its burning a lot of oil.
In order to do the JDM K24a swap is it a straight drop in or are there things that I should be looking out for?
From what I understand, it's completely different. Your K24A2 has 3-lobe VTEC while the K24A is just intake side.
With that being said, you'd at least need a new wiring harness, and probably a different ECU. K24A2's aren't that expensive anyway.
I believe only the k20a has a 3-lobe VTEC head as far as JDM engines are concerned. The RBB head only applies to the K24A2. If it’s an RBB head, then you should be fine.
Send a link/photos. That will help.
@_Sam where are you getting this info from? Regardless.... It's wrong. I've put a JDM K24A into a TSX... Twice. No offense meant.
@HunnyBuilt there are JDM K24A's that work in the TSX. Before you purchase, ask the seller to pull the valve cover off and send you a pic of the cams. If they have 3 lobes per cylinder on both cams, it's the right engine.
With that said, ONLY the long block transfers. The water jacket and accessories do not work with the TSX. I've answered this question multiple times, if you crawl through my post history or search K24A with my username you'll find all the details that make it work. Hint: you don't need a new wiring harness. Good luck!
Discussion Starter · #7 ·
@shandalo So all my current accessories, ECU and wiring harness all work with that specific K24A?
Correct. Strip the new engine down to bare long block, including removing the water jacket it comes with, move all your stuff over. There is also a sensor on the USDM vtec solenoid not present on the new engine's solenoid, remove the plug, install the sensor. A couple of other small things I can't remember at the moment. If you don't find the info beforehand, no worries, you'll notice during install.
Discussion Starter · #9 ·
@shandalo awesome! Thanks for the tip
Another question is the TSX type s the same motor as the USDM version, with the 3 lobes?
Yes everything will work, you have to take entire water pump housing off Jdm and swap with your US spec, threads are all the same, engines are basically twins if you want to call them that. I bought a TSX belt and tried putting it on with Jdm housing and accessories and it was too short, not to mention due to the housings things are placed slightly differently as well, hope this helps.
I just did my swap and have been driving around for a couple days now. The power seems way down tho and the vtech cross over seems non existent. Is this normal? I swapped the JDM K24A RBB3 into a 04 tsx. I'm running a factory ECU no tune and factory intake and exhaust. Exhaust is extremely worn and the primary/upstream o2 sensor code stays on/comes back after a reset. The car had a damaged motor when I got it so I have no bearing on what is normal. I do own a 9th gen SI with the k24Z and can say it is much quicker and has that throaty VTEC cross over compared to the TSX, but I figured the TSX would be comparable.
I just did my swap and have been driving around for a couple days now. The power seems way down tho and the vtech cross over seems non existent. Is this normal? I swapped the JDM K24A RBB3 into a 04 tsx. I'm running a factory ECU no tune and factory intake and exhaust. Exhaust is extremely worn and the primary/upstream o2 sensor code stays on and comes back after a reset. The car had a damaged motor when I got it so I have no bearing on what is normal. I do own a 9th gen SI with the k24Z and can say it is much quicker and has that throaty VTEC cross over compared to the TSX.
Do you know what year? My Jdm was an 08 so I just picked up an 06 TSX ecu to get it running that could be your issue, or that upstream sensor could be as well. Check over connectors and wires look for any torn cut or corroded. I got mine running but it’s into a custom setup so it takes longer to get things done than they would normally. I’ve read that vtec comes in about 6k rpm so yeah it takes awhile unless you get it reflashed which brings it to 4K or 4500k rpm.
The JDMk24A rbb is the one with 3lobes cams.the USDM TSX from 06 to 08 has 205hp but the torque is bad.The JDM k24A is a better engine so far and it comes from a Honda Accord Type S in japan
correction, the jdm honda accord CL9 have 3 lobe on both Intake and Exhaust , i have one thats how i know, and its a TSX
The JDM k24A has 200hp and about 173ft torque while the 04 to 05 TSX k24A2 has 200hp and 165ft torque and the 06 to 08 TSX has 205hp and 165ft all 3 of them has 3lobe..the k24A3 and up are the less favorite engine for anyone.
1 - 20 of 27 Posts
