1 - 1 of 1 Posts
JL AUDIO A6450 CAR AMPLIFIER
PRICE: $150 O.B.O
Came off a 2008 ACURA TL-S. All wires used are intact.
JL Audio builds their A-Series amplifiers with the high-end technology that's made their amps legendary. These hard-working amps feature an advanced thermal and low-impedance protection system that doesn't shut your amp down when the going gets tough. Instead, it rolls back peak voltage demands to protect the amp, while continuing to play your music at a safe power level.
The A6450 6-channel amplifier puts up to 110 watts RMS out each channel, and JL Audio's patented Class-AB amp circuitry delivers exceptional, natural sound with extremely low distortion. JL Audio amps use "differential-balanced inputs" to isolate the signal's ground from the chassis ground, reducing noise and making this amp compatible with almost any system, including most factory radios.
Tunable high- and low-pass filters, and a bass boost give you precise control over your sound. The optional RBC-1 remote lets you dial in your bass from the comfort of your front seat.
Details:
6-channel car amplifier
at 14.4 volts:
70 watts RMS x 6 at 4 ohms (110 watts RMS x 6 at 2 ohms)
220 watts RMS x 3 bridged at 4 ohms
at 12.5 volts:
45 watts RMS x 6 at 4 ohms (75 watts RMS x 6 at 2 ohms)
150 watts RMS x 3 bridged at 4 ohms
Advanced Rollback Protection System
variable high- and low-pass filter (50-200 Hz, 12 dB/octave)
switchable bass boost on ch. 5 and 6 (0, 6 dB at 48 Hz)
optional wired remote bass boost
Absolute Symmetry™ Class-AB amplifier design
MOSFET power and output stages
preamp-level inputs
speaker-level input with optional converter
4-gauge power and ground leads and a 60-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 60-amp in-line fuse between the distribution block and the amplifier is recommended
18-1/8"W x 2-1/2"H x 9-1/4"D
PM or email [email protected]
1 - 1 of 1 Posts
