1 - 3 of 3 Posts
Hi,
Im looking for some help for My 2005 Honda CRV (DBW) 5 speed manual. *I know this forum is for TSX, thought you guys would have some suggestions or tuning solution that could be tried on the CRV K24A1
My 2005 CRV runs a PPA series ECU and has DBW. It runs only MAP (no MAF) and also has intake runner valve/ butterfly. Need a tuning solution like KPro that I could use to run a turbo setup with much larger injectors. Iam ok with limited draw backs like.. VSA not working and other small niggles.
I dont want to go standalone. Hoping I can make some tweaks and make a dual ECU setup work on my CRV K24A1.
I was looking at other similar K24 engines. Came across Honda Element (07-08) which seems quite similar (DBW). Element 07-08 ECUs are supported by KPro or Ktuner..I forget which one.
Wondering if I could use TSX or any other KPro ECU with KPro dual harness and make it work with the stock CRV ECU.
Hoping experienced guy here would be able to chime in..
Thanks in advance ...
Hi,
I have the exact same problem. I own an 04 crv and I have kpro and turbo on my ep3. I'm getting conflicting reports about using my ep3 ecu in my crv. Some say it could fry the ecu. Have you found any ktuner setup that works on the crv?
Pat
Hi,
Bump, another CRV owner here trying to look into how to get something like this to work
1 - 3 of 3 Posts
