Ok, well, obviously I have the TL - but I am pretty sure the installation for the laser jammer is the same in the TSX. The only difference would be that if you wanted to put the display in the center console, you do not have to disassemble the entire dash, you can simply pull out the center container to drill the hole.
Oh, also, the fuses may have a different layout in the TSX than the TL - so you want to check to make sure you are using the correct one.
And, in the trunk, the TSX has a lot of little plastic pieces also, but they use a phillips screw instead of a simple pop out like in the TL.
See the web site to try to understand what on earth I am speaking of.
http://www.acurakid.com/laser.html
