1 - 7 of 7 Posts
Brake engages mid way to floor, it engages normally if i pump the brakes a little
Now i know this means air on the lines but i have bleed the brake lines twice now and almost emptied half of the brake fluid bottle. i even followed the proper LF, RF, RR, LR the second time i did it and still no changes to the brakes.
Any input is appreciated
Discussion Starter #5
Did you ever get this fixed @vash_021
Not really i changed the brake master cyclinder and it is still the same i will try to bleed all the brake fluid and go thorugh 2- 3 cans of brake fluid, work gave me a 2015 F150 to use and my car has just been sitting for months now
Discussion Starter #7
Yes sir exactly what it is bad master cylinder .
just changed master brake cyclinder along with my clutch master cyclinder(preferred to change this so that i dont have that delay valve on the clutch play)
and it did not fix my issue
I have no problems doing hard braking, the breaks apply quite good just that dead play in the begginning is annoying as when i switch vehicles i tend to over apply brakes
1 - 7 of 7 Posts
