1 - 2 of 2 Posts
All right so my 05 tsx driver side headlight has been messing with me. The problem was the light would turn off I had changed the bulbs from OEM to 8k HIDs they work fine for bout six months and now only the driver side is messed up. So I changed the bulb first but the flickering and the. Turning off continued so I changed then ballast same problem then I changed the ignitor and still te same ****in problem the light will stay for a minute or two then just turn off. If if turn the switch off then back on the headlight will turn back on but it turns off again after a couple minutes.
HELP PLZ
im sure u have, try checking all the wires, take the battery out so u have more space, and see if anything is shorting out, or maybe the wires are stripped or just worn, maybe they are being pinched...also did u check the fuse to see if its good? maybe its going bad as well...sounds like bad wiring, i could be wrong but check it out.
1 - 2 of 2 Posts
