Hi Guys,
I recently purchased Buddy Club N+ Coilover and installed it on my accord euro cl9 (right hand drive)
my questions:
1. Do you need to install the 'washers' that is provided for the rear buddy club n+ coilover? coz mine could not fit - so the mechanic did not install it.
2. My passenger side sits higher than the driver side - why is that?
passenger front is 1.5-2.3cm higher and the rear passenger is 1-1.8cm higher. approx.
i have measured the spring and grove accordingly and also measured the car from the centre hub to the fender.. (during oem spec and installed bc n+)
- front spring: 20cm front grove 12cm
- rear spring: 24cm rear grove 12cm
3. Im hearing a thumping noise or something loose on the rear - but can't seem to isolate where it is.. this happened after the coil over installation. any ideas?
4. The mechanic that installed my ingalls camber kit and took off the endlink (moog) - do you think thats what cause the height variations due to sway bar & end link was not properly realign?
any help would be awesome! thanks heaps...
ps. i have searched everywhere but could not find a proper solution. I hope you guys could help a brother out
my questions:
