I was wondering if anyone else has encountered the same issue I just went through. I have had a pull left on my 04 TSX since I bought it. The pull has recently gotten worse so I have taken it to the dealer to get an alignment. Following 3 trips to the dealer and 3 seperate four wheel alignments the car was still pulling to the left (if not worse that when I started this process).
We then tried rotating tires from back to front then from side to side with no help resulting (thinking that there was a bad tire).
A call was then made to Acura engineering and the dealer was told to adjust the front subframe in order to properly center the camber. So far this seems to have fixed the issue. I am concerned that a car with only 5000 miles needs an adjustment like this (actually has needed it since 0 miles).
Has anyone else experienced issues with pulling or have any experience in adjusting the subframe?
