G
Guest
·Is there a manual override in the TSX? Lets say I took the 5 speed AT Transmission, could I like still change gears manually?
Hey Rod,jolt said:I'm from Sydney, Australia and my wife has a 5 speed auto/tiptronic Accord Euro.
What I'm wondering is if you know of anybody who has been able to change the downshift restrictor points in the gearbox ECU??
The reason is that you can only downshift manually to first from second when <2,500rpm whereas you can shift down to any of the higher gears from <4,000rpm. Some really tight corners are too tight for second gear and you have to slow down too much to get it into first!!
Apart from the obvious guess that it is done to protect the engine/gearbox, does anybody actually KNOW why it is so low to get back into first?
thanks
Rod
