1 - 13 of 13 Posts
flashprroooooo!!!
source parts from k20a.org? if you have to go through a honda dealer, at least go with autofair.
Discussion Starter #5
Thanks for the feedback guys, I found a used trans for 700. I wanted to rebuild the whole trans. Due to grinding and having to force it into certain gears.
Aussie Aussie Aussie
replace with a type r gearset.
I think that is the Civic Si for Americans.
oh
and lsd
and better final drive ratio
I think that's it
oh..
do lightened flywheel and upgrade clutch while you are at it.
that's all
  • Like
Reactions: Dir7y
Sry to hijack your thread but i didnt want to make another thread to ask my question so here it is:
If i change my final drive to 4.7 from my original euro final drive ratio of 4.3 will my speedo/odometer be off?
Yes.
You can correct it with a Dakota Digital after.
....its fate....
I have changed mine to 4.3 also but it seems fine. I havent tested it though but it matches the speed to my gps - if that is even a reliable gauge.
From what i gather, speed is read off third gear, so i was told it wouldnt matter. So far i have had it for 9 months and i have had no speeding tickets and i travel the same as other commuters at free flowing traffic going at legal speeds.
Correct
oh
and lsd
I think that's it
oh..
that's all
This is the EXACT setup i'm currently running to make my type R tranny lol. +06 Si gears and LSD with carbon synchros with an CTR 5.06 final drive and exedy stage 1 clutch with ITR flywheel. Since you're building your tranny, you might as well go deep since this is hopefully your only time you'll take out and apart the transmission
Just wondering why you went with a 4.3 final drive?..
....its fate....
1 - 13 of 13 Posts
