1 - 2 of 2 Posts
Hello all,
My 2009 tsx has been running rich fir some time now and I think it may be the map sensor.
Does the 2009 model have a map sensor or just a maf sensor, if it has both then where is the map sensor located. Please and thank you.
Discussion Starter · #2 ·
Hello all,
I found the map sensor and switched it for one at a picknpull. The car was noticeably harder to start than usual and my idle was at about 1900 after warming up. It usually goes down to 500/700, does anyone know what this means? I switched back to my other map sensor the next day so I wouldn't make the problem too much worse.
1 - 2 of 2 Posts
