I hate starting new threads on problems that have been talked about before. But, I decide to start a new one so I could ask my own questions…
About six months ago I noticed that the clutch pedal started to get soft and grind a little here and there. This was a couple months after installing all my Shifter parts. ( CT SS, HR Bushing, Base bushing.
I started to get a little more worried when the clutch pedal was getting very soft, and grinding a lot more then normal. Also, the clutch pedal starts to engage about ¼ inch off the ground. I have tried everything, and can’t get the clutch to slip in first or second gear.
This morning I tried to adjust the clutch master cylinder as some people mention to do, with little, to no results. I ordered the Slave Cylinder and will be replacing that tomorrow. If that doesn’t fix it, I will be going with the Master Cylinder next.
I also checked the clutch pedal, and from what I can see, there is no cracking what’s so ever. Can anyone chime in on this? Some people swear it’s the clutch, as other say the hydraulic system.
