1 - 20 of 67 Posts
The car still has some ways to go before its done (boosted that is). But now begins the fun part and that building the turbo set-up.
I'll take plenty of pics in the process of the turbo build.
Enjoy :D
ps. there are some old pics from when I first started my build thread....sorry
Wiseco pistons (87.5mm & 8.8:1), ACL bearings, ARP studs
Manley turbo tuff rods
Supertech dual valve strings, titanium retainers, seats
New K24a2 crank & ERL s2000 oil pump
Competition Clutch super single disc
Motor pulled
Port and polished head by Westside
Getting ready for assembly
Crank was rebalanced & coated by Westside
Golden eagle sleeved block. Bore & hone by Westside
VTC (intake cam) was machined to advance to 45 degrees
Brain Crower stage 2 cams
Discussion Starter #2
Wrapped up for another day
Ended up using the RSX-S oil chain guide (not shown) because the k24 rubbed too much
Hybrid-racing tensioner
Waiting on parts so decided to repaint the block, tranny, and other miscellaneous parts
Installing the fluidampr crank pulley
Clutch and tranny going in
Motor went in quick and easy
Drive Shaft shop axles (level 2.9)
72mm Skunk2 DBW TB (1st of its kind)
Had to purchase a new 06+ si TB since the TSX covers was slightly different
RRC intake manifold. ported & borematch by Westside
ID1000
Catch can
After powder coating
Fuel upgrades and adding a return line
Discussion Starter #4
Building the feed/return fuel line
Fuel pump tucked behind the exhaust heat shield
Fully protected behind the heat shield
Return line
Electrical for the fuel pump
Hondata K-Pro
I'll post pics as it sits now as soon.
....its fate....
OMG!! You are officially the baller of this forum!
Didnt you supercharge your automatic before?
Then did a manual swap?
Now you're doing a more than impressive turbo build?!?!
Most members here would be very envious of you, me included!! :cheers:
BTW, how much did your manual conversion cost?
Its something that i might be considering myself later on :)
Pistol Grip Pump
I love you O.O
Epic. Those pictures were so fun to watch.
Triple Platinum Member
What shop did this machine work?
1 - 20 of 67 Posts
