1 - 7 of 7 Posts
I just had my pro-kit installed on my car and all I can say that it was a great decision... I would break it down for you guys
Looks: eibach definitely made the car look sportier and aggressive. it is just perfect drop. Last thing I wanted , was my TSX to look ricy.
Handling: I feel almost no body roll when cornering
Comfort: I know many of you are going to disagree with me but my car is smoother and I can almost say that less bouncy than stock. Maybe OEM springs really suck.
Disadvantage: I need a camber kit
This is my second set of Eibach pro-kit. First I had them on my Accord and then on my TSX. I would totally buy them again.
As soon as as a set of Kony shocks comes out I would put them on
I hope this helps some of you to make your desicion when buyin springs.
How much do they lower the car? Are htey progressive rate on both front and rear? How is rebound with the stock shocks (under control or a little excessive)?
Finally, do you think you need a camber kit on both front and rear, or are the stock adjustments capable of putting you within spec?
Thanks a bunch,
-Alt
1 - 7 of 7 Posts
