Hi all, I am new to this forum and just got handed down 2005 TSX.
I can't stand the factory stereo setup and will be going to switch to aftermarket stereo equipment.
I noticed there are total of 6 speakers in the car (2 front with tweeter, back door and Real 6x9).
Did anyone switch all of these before?
If so, how painful is this installation?
I noticed that TSX does not have any afrtermarket dash kit due to HVAC control or something so I am guessing that I have to buy that original cassett kit which install my head unit to below.
One question i have is which harness do i have to buy to make this work with factory unit?
I will post pics as I install. This is going to take me a while...
Here is my list of equipments that I will be installing.
Head Unit: Pioneer 80PRS
Amp #1: Audison LRX 4.1K (Rear speaker + door)
Amp #2: Audison LRX 2.9K (Front Speaker)
Amp #3: Jl Audio 500/1 (Sub)
Front Speaker: Boston Acoustics 6.5Pro or Focal 165 KR
Real Speaker: Hertz Space K6L / HSK 6.5 coax
Sub: JL 10W7
As I progress, please help :)
thanks
Waste of money running two amps for speakers. Not to mention waste to have the rear decks at all if you're running a sub. You only need front doors and rears if you want rear fill or have passengers back there regularly.
And, should just run a JL Cleansweep rather than going through the hassle of fitting an aftermarket HU.
Thanks for the feed back.
I guess your right on one thing is that I will just have front and rear speaker and forget the back door.
All these gears are from my previous car before crashing it... So I didn't have to fork out any money for this.
I would also want to use current stock OEM stereo, but it does not work except for am/fm. It costs same or more than to get after market HU than fixing the current one and sound quality will be much better with after market HU.
thanks
if you want to run an aftermarket head unit you will need the Audio Attachment Kit P/N 08A03-5E2-000 shouldnt run you more than $80 ( i payed clsoe to that ) and the Honda T Harness Amazon.com: Scosche HA09B 2003-Up Honda Accord EX V6 Radio Relocation Harness: Car Electronics, also might want to look into Honda Factory Amp Bypass Harness Honda Civic 06-Up Amplifier Bypass for Premium Sound
This is the most helpful information!!!
I want to kiss you right now :)
thanks
