Anyone know a good place to buy a Amp Kit? I need to hook up a JBL GTO1004 4-Channel amp, 150 watts x 4 RMS, JBL BPX500 500-Watt Parallel/Bridge Subwoofer Amplifier, 718 watts RMS. What size gauge wire and fuse from the battery? Thanks for any input!
A 1/0 gauge dual amp install kit with an 100amp fuse will do the trick. You can use a 4 gauge kit but you're limiting yourself if you're running two amps. If you're buying online, make sure you're purchasing true AWG and copper wiring. There's a lot of false advertising out there.
Thanks for info stoffius!
