Need help! Clutch problem
2275 Views 4 Replies 4 Participants Last post by  tottenham12712
Hi guys, i have a found multiple thread about clutch problem but i am not sure, its respond to my problems.
I've got a tsx 04 6MT, and i have problem with the clutch, like it doesn't disengage completely when i push the clutch down to the floor
The symptoms:
-All the gears (also the reverse)shift well until the car is hot
-Its impossible to engage in reverse when its hot, and every gear are hard to shift.
-A click sound on the pedal
-A strange feeling on the pedal when the car is hot
-When i've got the pedal to the floor, i shift in first gear and the car want to move
-When i do a clutch test, it doesn't slip
I've bought the clutch kit, its seems to be a big job to change the clutch and i am not even sure if its the clutch or the hydraulic clutch system that doesn't give enough pressure to the clutch that caused it doesn't disengage completely at 100%.
I dont want to put 10hour on the clutch and 500$ later to have the same problem.
-Master cylinder or the slave cylinder?
-The pressure plate or whatever in the clutch
-Air in the clutch hydraulic system?
I have bleed the system with my friend, its goes well for 5mins and the hard shifting come back and the reverse grinding, impossible to put it in.
Thank you for help!
Adjusted my clutch pedal travel arm. Solved my issues completely. No more grind into reverse and smooth as silk into 1st and 2nd.....butter smooth. Car was not even driveable. When you pushed the clutch in to put the shifter into first gear the car would start to creep forward and wouldnt even go into first.
Wish I tried looking for a pedal adjustment a long time ago.
This completely fixed the problem, no issues since~
I would def try adjusting the shaft on the pedal. I just did my master cylinder and that fixed the 2nd, 4th and reverse slight grind I had but I am not sure if it was from a weak master (it was bad, squeaking and not feeling smooth) or the adjustment. I didn't touch the new one and have good free play when the pedal is out as well as about 1/2"-1" off the floor till it grabs.
Its not the pedal adjustment because the engagment point is at the right place on the pedal
That doesnt mean much because it could have already been adjusted previously. You're most likely at the end of your clutches life.
