I just replaced the low beam headlight, ballast and igniter on my 2005 Acura and the light still does not come on. I purchased the parts from Ebay. Any advice??? Please
Most total headlight failures are caused by a bad component like a fuse, relay, or module. Wiring problems can also cause both headlights to stop working. High beam headlights don't work or low beams don't work. If just one bulb fails to work in either high beam mode or low beam mode, it may be the bulb.
I'm having the same issue. Did you ever find a solution?
